Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Smart66's Avatar
    Dec 2020
    Did you turn on the car for some time before writing via KESS?
  2. #17
    autobo's Avatar
    May 2014
    Bulgaria
    You can recover this ECU with KESS,just in settings set minimum speed.
  3. #18
    Smart66's Avatar
    Dec 2020
    You should have said it earlier because he'd brought ECU to service Speed changing is only possible via K-line interface?
  4. #19
    Jul 2020
    Quote Originally Posted by autobo View Post
    i did try to read or write or id the ECu changing all the speeds settings,first thing i did was minimum speed,but the same result,wake up error
  5. #20
    Jul 2020
    Quote Originally Posted by Smart66 View Post
    yes he did started the car after i read the file with kess,the car was not at my garage,after i read the file,i went to my garage and after i came back to write it back,meanwhile he did start the car,a few times i think,he told me after,i did not think about telling him not too
  6. #21
    Aug 2015
    Quote Originally Posted by danny012 View Post
    It is edc16 and you are reading/writing only flash part (maps) it is unchangable memory and it does not matter if he started car inbetween reading and writing
  7. #22
    Smart66's Avatar
    Dec 2020
    If car was working for a some period of time before writing, battery voltage will be higher than usual. It can cause rapid voltage drop
  8. The Following User Says Thank You to Smart66 For This Useful Post:
    danny012 (29th August, 2021)
