Results 1 to 15 of 22
    Jul 2020
    Default ECU Wake Up Error after writing with Kess V2
    Hi guys,
    Can anyone help me with an advice?
    i read with kess v2 the file on a skoda octavia 1.9 tdi BJB 105hp,2006 and everything went well,
    when i tried to write back the file,it did not go further then 0% and said error communications,try recovery yes or no,
    and the recovery did the same thing at 0%,now the ECU does not wake up and the car wont start,there is no communication
    with the engine when i try to do a diagnose with delphi,the other modules like ABS,Immobiliser works to do diagnose on them,only the engine does not,
    tried ID and Read with Kess v2 and comes up with same error Wake Up Error.
    the battery voltage was above 12v all the time,never happend before on the rest of the cars that i did read and write files
    i have the original file and the ID that i read with Kess V2.
    HW: 0281011883
    SW: 1037371259
    VIN nr.: TMBBS41Z462264021
    SW ver.:
    Spare:
    Engine: R4 1,9L EDC
    HW Ver.:
    SW upg.: 03G906016DJ 6250
    Bosch EDC16U1
    Does anyone knows a solution how to wake up the ECU?
    i also have Ktag,Mpps if there is a solution to wake up the ECU with them.
    Thank you
    tepSIJA's Avatar
    Dec 2015
    OTP
    try to recover with MPPS if not help than find original flash and writte with KTAG in BDM mode on bench.
    clone tools ... sometimes it must hapened you brick ecu .
    Tempus Omnia Revelat
    Smart66's Avatar
    Dec 2020
    Probably,you've bricked your ECU. Try with KTAG in BOOT mode to write original flash. If It wouldn't work, you need to find other ECU and clone it
    Jul 2020
    i will try to do it this way,i was not sure if i could write with Ktag a file that i read with Kess,because i never did it,
    my next move was to take out the ECU and try to put it on the bench with Ktag,maybe will wake up the ECU.
    i will do it today and report.
    thank you
    Jul 2020
    i will try this way as well,i only have the original file that was read with Kess,
    do you think it will be ok if i try to write the Kess file with Ktag or are they different types of readings?
    Thank you
    tepSIJA's Avatar
    Dec 2015
    OTP
    Quote Originally Posted by danny012 View Post
    Thank you
    Files are different, u can't read with kess and writte with ktag
  7. The Following 2 Users Say Thank You to tepSIJA For This Useful Post:
    danny012 (29th August, 2021), dantetimoc (27th August, 2021)
    dantetimoc's Avatar
    just read in BDM your dead ecu with Ktag, Galletto or what you have... post here BDM read file and OBD read file with kess... and i will make you a repail file from 2 readings to write back in BDM
    Autotuner- Kess - Ktag, genuine master tools.
  9. The Following User Says Thank You to dantetimoc For This Useful Post:
  10. #8
    fudballer's Avatar
    Aug 2019
    Serbia
    You can't do EDC16U1 with kess i tryed many times and kill ECU same way like you and only way i recovered it was with Galileto by OBD
  11. The Following User Says Thank You to fudballer For This Useful Post:
  12. #9
    Smart66's Avatar
    Dec 2020
    Try it today and report results
  13. #10
    Jul 2020
    I have read the ECU with Ktag,the eeprom and micro files,i have attached the files and the Kess read
  14. #11
    Jul 2020
    You are not the first person i heard saying something similiar about Kess,maybe i shoud get a Galleto then for the future
  15. #12
    fudballer's Avatar
    Aug 2019
    Serbia
    Kess did some EDC16u1 ecu's like i menaged to read/write Golf 5 2.0 103kw Edc16u1 with Kess but i could not write the Golf 1.9 74 or 77kw i don't remember i had to use Galileto v54. If you want to do chiptuning you have to have a few tools you can't stuck with one tool it's just how this job work's.
  16. The Following User Says Thank You to fudballer For This Useful Post:
  17. #13
    Jul 2020
    Quote Originally Posted by fudballer View Post
    Yes i agree with that,at the moment i have Kess,Ktag,MPPS,i was thinking about getting a Galleto as well,but since i had no problems before now with Kess,i was thinking that
    i will be able to go on just with this 3,and in time when i encounter a different ECU that requires a different tool i will get it.
    thank you for the advice
  18. #14
    Jul 2020
    Default Update
    I send the ECU to an expert in ECU repairs to have it check,and he ask if the owner of the car jump started the car with the jump start robot,and he actually did
    right before i come back to write the file back because the car baterry died,but he forgot to mention that to me,from what the expert said,the owner jump started the car with the robot and the high voltage that he select may fried the ECU,but he is not 100% sure,i dont know what to think.
    Its possible to brick the ECU if the voltage drops for a few seconds?
    I may just get a complete starting kit from scrap yard,ECU,Dashboard,Key etc,i found a few near me for exactly the same car,with the same engine code,
    so that will be the ultimate solution
  19. #15
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Sometimes hapend when car make ticking noise (if you have weak baterry and key is on) If you hear this ticking noise, need disconnect batery or connect charger or something.
    Its need to be quick, because ticking can put ecu in boot mode and erase some datas.
    So maybe is cgarger conected to late.
    Kess dont write you 5 times - connect baterry to stabilized charger?
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  20. The Following User Says Thank You to Pyromaniak For This Useful Post:
