Results 1 to 1 of 1
    number7hd's Avatar
    Dec 2013
    Default VW EDC17c74 change soft number
    I need to flash ECU online and need correct SW.
    Now SW is 04L906026LQ_5172
    Need 04L906026GP_3020 - should be 3021 but to make update - it should be lower
    I can't reflash ECU to correct SW, couse on FLASH DISC there is no SW FL04L906026GP_3021.frf...
    It's not enough to change only in non crypted area...
    THANKS FOR HELP !!!!
    If my solution helped You - do not forget to THANKS !!!
