Threaded View
    nezocas's Avatar
    Dec 2015
    Portugal
    Default Audi A6 ELV module
    Short story, car went to change the motor oil and gearbox oil, not sure what the mechanic did with the car.
    It died there, upon DTC´s check, they norowed it down to the stearing lock colum ecu.... ELV.
    No ligths on the dash, it does not unlock the stearing wheel, does not fire up the engine.
    The relay on the module was unsoldered and tested on the bench....and also the 3 microswitches
    Audi A6 2.0 from 2007
    I there any way to bypass this module, and put the car again in working order...???
    Eeprom and flash was read with Xprog with the secured option and adapter 1-002-0017, using the xprog connections pdf.
    MC9S12DG128
    1L59W
    Can someone chek this files to see if anything is wrong...???
    Best regards
    X-Prog 5.60 / Upa-Usb 1.3 / CarProg 4.74 and 7.28 / MiniPro / Galletto 4 VD300 / Digiprog 3 / SVCI 2018 / Autel MP808 / Autocom 2020.23 / USBDM / Skyprog / RT809H / R270+ / Lexia PP2000 / VCDS / Op-com
