Results 1 to 5 of 5
    May 2021
    australia
    Unhappy 2006 CHRYSLER 300, car IGN on ok, NO CRANK
    Hello to all friends, I have here 2006 CHRYSLER 300 car IGN on ok NO CRANK, have two keys, both can open and close car, but ignition on ok and no start car. when read code (column lock module internal) who can guide me how to fix this
    manoj
    keturi's Avatar
    Oct 2010
    Lievatu
    Did you tried cut tyre pressure monitoring wire from esl-ezs? Leave esl wire just connected to the ezs, because here is common problem when one of TPMS receivers have short circuit and don't let unlock esl.
    As you asked before in PM, I attached EZS dumps as well.
    May 2021
    australia
    I tested wiring from stater relay 30 power ok and 87 when i jump positive feed starter = turn OK ,
    Relay terminal 85 when i turn key start position = power OK
    Relay 86 terminal wire coming from ENGINE ECU =wire OK but no signal active relay
    *fault code steering column module internal
    #MEASURING VALUES W CM/TPMS
    measuring value ELV (Steering column lock present = false key prog =OK NGC/SKREEM Status=kill command
    left rear trigger present =false pin successfully prog =OK skreem seed request =false
    right rear trigger present =true skim =TRUE valid skim key =true
    rear left and right =true ECU STATUS =Normal mode
    manoj
    May 2021
    australia
    Quote Originally Posted by keturi View Post
    #MEASURING VALUES WCM/TPMS
    manoj
    cinici's Avatar
    Jan 2012
    TURKEY/BURSA
    i have the same problem ezs and key check ok there is no error ecu no error code tire pressure failure does anyone have an idea of the dashboard
