Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Aug 2020
    Default DS150 good quality single board required components
    THREAD CLOSED
    HaynesPro online + 2022.02a version available, message for where to get it!
  2. The Following 29 Users Say Thank You to crouchinggerbil For This Useful Post:
    1z4x7 (26th September, 2021), 340mtx (12th March, 2022), Col19 (20th November, 2021), francvito (5th May, 2022), fuzz1 (11th December, 2021), Hibvr6t4motion (15th October, 2021), hk675 (17th September, 2022), HoSi74 (3rd November, 2021), Jezza012 (5th June, 2022), josmatos (15th May, 2022), Jukica (29th October, 2021), KADE007 (13th October, 2021), khoums (28th September, 2022), kingarthas (19th September, 2022), Mario6 (20th September, 2021), Markhodges78 (7th September, 2021), massimassi (11th November, 2022), mkii (31st December, 2021), obd2cartool (17th October, 2022), ombre57 (15th December, 2021), p38 (7th September, 2021), prodlt (4th November, 2021), R20VT (25th September, 2022), Salah Bismilah (10th December, 2021), samobelix (16th September, 2021), sympho (4th December, 2021), TudiM3 (7th October, 2021), xcjps (8th September, 2021), zukosok (23rd February, 2022)
  3. #2
    Jun 2018
    Hello, would this (two board with bluetooth) work with 2020 software and new firmware. SI9241AEY already replaced, is it necessary to change something else? Like can filters? Now it works great with 2017R3
    Aug 2020
    Quote Originally Posted by etzkaaa View Post
    They work but they are really CDP and not the new CDP+ they will not read all cars, they are not capable of the newer protocols.
    This is why we recommend single pcb instead because they are really CDP+ and can read all protocols.
    Also, you will read nothing on that dual board with newest firmware on it.
  5. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    mann357 (24th March, 2024)
  6. #4
    Jun 2018
    Quote Originally Posted by crouchinggerbil View Post
    What makes them so special (single board)? That they are able to read more protocols? Maybe a better cpu or another better quality components? What needs to be changed to make my two boards device work with the new firmware and 2020 software? Does replacing the cpu and other components not help?
    Aug 2020
    The single is almost 1:1 quality as the original tool.
    No amount of replacing parts on double board is ever going to make it work 100%.
    What do you expect when the tool is only €35?
    You want to replace cpu and other parts, why?
    Easier to just buy a good tool that works and have no problems later.
    It would be great if it worked but it does not, that's just the way it is.
    I can send you a link to a good supplier if you want, who we have had 0 problems so far with the boards.
    We have tested many suppliers over the last 5 months and these are the best ones so far.
  8. The Following 3 Users Say Thank You to crouchinggerbil For This Useful Post:
    340mtx (12th March, 2022), Col19 (20th November, 2021), stefaudio (21st December, 2021)
  9. #6
    Col19's Avatar
    Jan 2019
    France
    Hi dear friend Crouchinggerbi
    Thank you for the useful information, I confirm that with the dual card vci my old vehicle had trouble reading it, with the single card (fw3002) no problem. Following the purchase of a single card I was fooled with the bluetooth module and the relays.
    On the seller's image the relays had a power of 5V i received relays with 3V power, the bluetooth module was the high quality one with the STM32 board the one received was a cheap Beken3231 and the CAN filters were not everything simply not solder, 0 ohm resistors were placed, of course i add the CAN filters.
    I wanted to order 5V relays but after reading your post I gave up even if for trucks it is important to use 5V relays according to Russian forums. Thank you and respect for sharing your experience, best regards.
  10. #7
    Jul 2016
    Denmark
    Hello friend many boards come without this right here, do you know the part number?
    https://prnt.sc/21oxy0c
  11. #8
    Aug 2020
    Quote Originally Posted by sympho View Post
    Look at first post again I made some changes.
  12. #9
    Junior Member nfgrd's Avatar
    Apr 2017
    Tuga
    [QUOTE = crouchinggerbil; 4243453] Olhe para a primeira postagem novamente, algumas mudanças. [/ CITAR]
    I have this board, do I need to change the marked components?
  13. #10
    Mar 2021
    Quote Originally Posted by nfgrd View Post
    Your 2nd 3rd and 4th pic can't make them out....but I think they suppose to be 4 AND gate package.....1st pic suppose to be CAN filter.
  14. #11
    Jun 2015
    Hello, send me a link to a verified aliexpress seller.
  15. #12
    Oct 2020
    which seller does have a quality device without changing components
  16. #13
    Aug 2020
    Quote Originally Posted by asdfx View Post
    This is the only vci we recommend for this and the next releases
    https://obd2cartool.com/index.php?ma...roducts_id=123
  17. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    mann357 (7th April, 2024)
  18. #14
    Oct 2020
    but i don't see any can filter?
  19. #15
    Jan 2022
    Goodnight,
    I have 1 ds150 interface and I can't diagnose trucks with autocom.
    I've had cdp+ since 2017 and probably the quality of the components can't be the best.
    Can you tell me which components I should change and where I should buy them
