nobody knows?
Hi I have a problem when uploading the modified file, after uploading the car starts, but after 10 minutes the car can not start anymore there is an error p3028, in edec17c60 it was the same, but there is a solution for this, does anyone have a solution for this ECU MD1CS003 ?
nobody knows?
Perhaps it would be good idea to put original file with modified one, its probably checksum error
yes it seems checksum error.i looked with winols 1 block not okay
can you calculate? thanks
it's not checksum's fault, if someone has such ecu, please upload mod file and read it again
how would someone have such an ecu, please contact me
berlingo, rifter
I repeat, no one has such a car to work with?
I repeat, nobody nothing?
Hi Friend. The problem is in the secured area. What did you read and upload it with? A lot of hardware has a problem with disabling this flash area.
Hi friends
Did BitBox solve this problem or is it still the same?
Small circumstances produce great events : 02.47-tranquillité:
