Results 1 to 5 of 5
    3inferno3's Avatar
    Nov 2014
    Europe
    Default Opel Vectra Denso 3.0 dt dpf off
    vectra 2006 year.Hello everyone. I have problem with swiftec solution in this case.. after writing dpf off solution and disconnect all sensors temp and diff. pressure everything is ok. but dpf saturation filter from 0% increase...it's going to 200% saturation and yellow spring appear on the dash... In meansured differential sensor show 125kpa . and temp sensors show 300 and second 650 degeres. please for ZERO differential sensor and temperature sensors too. my mpc file has good solution egr now. problem is only with DPF OFF. Please for help
    3inferno3's Avatar
    Nov 2014
    Europe
    Who has solution dpf off?
    EU
    go to instrument cluster and change coding with no dpf with opcom you need pin in this case
  4. The Following User Says Thank You to tutzu For This Useful Post:
    3inferno3 (17th September, 2021)
    3inferno3's Avatar
    Nov 2014
    Europe
    Quote Originally Posted by tutzu View Post
    instrumment cluster has only one option - cruise controll on/off please for solution denso ecu 3.0 cdti.
    Sep 2016
    emulator kup i po sprawie.
    FILE SERVICE
  7. The Following User Says Thank You to voltechcar For This Useful Post:
    3inferno3 (18th September, 2021)
