Results 1 to 10 of 10
    Sep 2021
    Default Ford Transit Custom 2016 SID208 Ecu Password
    Hello there
    When reading SID208 ecu with my Magicmotorsport Flex device, it asks for a password. Do you have a password file?
    Dec 2009
    Garage
    You must read pass with your device for this ecu.
    First read pass for this ecu then you can unlock in bsl mode and write this ecu.
    I don t have magic flex device i work with pcm flash.
    BR
  3. The Following User Says Thank You to tomo776 For This Useful Post:
    pablo1971 (19th September, 2021)
    Sep 2021
    Quote Originally Posted by tomo776 View Post
    Bu ecu için pass'ı cihazınızla okumalısınız.
    İlk önce bu ecu için geçişi okuyun, ardından bsl modunda kilidi açıp bu ecu'yu yazabilirsiniz.
    Magic flex cihazım yok pcm flash ile çalışıyorum.
    BR
    Ecu has been replaced by someone else before. so when trying to read it asks me for password. magicmotorsport(flex) asks for password when reading. Error reading trasdata and k tag. is there a way to read this?
    treble6's Avatar
    Nov 2008
    ktag reads it fine and you can also unlock it
  6. #5
    brend's Avatar
    Oct 2015
    Same where
    As I know sid 208 have power protection,.....and for work in bench power must by 14 v not 12 v .
    With 12 v nothing , no pass ,no read.
    NB!!! Don't ask in PM old file password , Im not remember.
  7. #6
    Sep 2021
    Quote Originally Posted by treble6 View Post
    I don't know if it's because of the password but it doesn't read the k tag. I have a clone k-tag device so it might as well be.
  8. #7
    Sep 2021
    Quote Originally Posted by brend View Post
    I did not know that. I'll try and post the result here.
  9. #8
    Sep 2021
    Quote Originally Posted by ryzen View Post
    unfortunately 14v didn't work
  10. #9
    treble6's Avatar
    Nov 2008
    which version of ktag are you using and post picture of connections
  11. #10
    Dec 2020
    If ECU has been replaced before and has been cloned without password adaptation, you will never read this ECU.
    Only who cloned this ECU can read it again..
