Hi to all,
my personal car is having some problems, like hickups, sometimes want start, and sometime just turns off while driving.
We have checked everything and some repair guys sugested me to change ECU.
I do a lot of electronics, so soldering and checking is not a problem for me.
I did open ECU, but I do not see anything that would be problematic.
But I still decided to clone my ECU to second one and try with that.
At that point I did not nottice that EMS3132 has multiple part no. so I bought different one.
My ECU is: 8200326395
Replacement ECU: 8200483732
The hardware is the same, but I do not know if only difference in those units is in flash, or code for Infineon is also different?
If different I assume it is not possible to extract ECU software with some JTAG and program replacement unit?
Or if some user here is from Zagreb and have some solution/clues for me please contact me with DM.
I have some more info.
VIN needs to be changed, but I am not sure is it also in Infineon flash - or just in external flash?
If it is in Infineon I need wiggler or I will make one from FTDI, and try to read internal flash of Infineon.
All EMS3132 MCU might have same code running, difference could be just internal and external EEPROM.
If I understand this thread correctly https://www.digital-kaos.co.uk/forum...73#post1891573
VIN is in flash, but I am not sure is it also in Infineon internal eeprom.
Will continue this thread and wrote my expierience if I find something more ...
Thanks,
Goran
