    blerim shehi's Avatar
    Jul 2012
    Albania Tirana
    Default CAS 3 + 61.35-9147217-01 REPAIR
    CAN ANYONE HELP ME
    I need to repair eep FILE CAS 3 0L15Y
    61.35-9147217-01
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by blerim shehi View Post
    CAN ANYONE HELP ME
    61.35-9147217-01
    what is the PROBLEM other then " repair eep FILE" ??????
    Jul 2012
    Albania Tirana
    problem is key llost.. can't not found ISN number of in this cac3+.i read the eep ecu 95640 and create the key on vvd2 only remote work open the closet door..the car not starting..
    thanks..
    Dec 2018
    Key 3,4,5 is LOCKED
    Apr 2016
    updated to high security version, no chance to decrypt with your knowledge
    pepi's Avatar
    1 With VVDI2 try 64 attempts method or
    2 Decrypt from EGS ISN and the last
    3 is find same dumps from the same CAS with known ISN
    - make key from dump
    - write VO from ori cas dump
    - write coding from ori
    - write long and short VIN
    - write ISN from DDE
    - Reset and sync EGS.
  7. The Following User Says Thank You to pepi For This Useful Post:
    Hayssam1 (6th June, 2022)
