write first original file and go test.
hello. i have little problem.
in the file I did stage 1 and dpf off.
now the car is ok 170ps but during the load it cuts off the boost. Could someone see the file or are you ok ?.
in 3rd gear it cuts 3500rpm
in 4th gear it cuts 3200rpm
in 5th gear it cuts 3000rpm
I have dyno tested files for this cars without cutting or problems. Works from 1st time and good safe power
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Ori file is fine. Cat have 142ps on dyno. I don't know where is problem. When i test car all log's are fine
Same torque limit miss, driver wish miss, rail pressure miss.
Maybe this is problem.
I did a lots of this edc17c42 and no problem.
File service, Custom Remapping, stage 1 & 2 dyno tested.
Petrol + Diesel
Adblue dpf egr Only tested working solutions.
Use thanks and Rep if my help was helpfull.
volvo grycife tu eres tonto
