Hello all!..........
hello, Vivaro / traffic 2015-on Power steering pump
Does anyone know how to change vin in pump ? renolink has the option but fails every time
The Power steering pump is a used unit, So has allready been coded, Is there any way of virgin the unit?
I can read the chip inside (
xc2365b ) with VVDI PROG. I have not tried this yet but it is supported on VVDI PRO ( under MCU, INFINEON-XC2XXXX, Chip xc2365b
Maby I can edit VIN in MCU dump???
I am really stuck, There must be a way of recoding a used pump.
In renolink its under (Trafic 3, EPS, Identification, I insert new VIN then click Write Vin but it fails ????
I think it fails beacus the pump is already coded.
Chip inside is xc2365b Part number 491100616R
