Results 1 to 5 of 5
    temur38's Avatar
    Oct 2018
    Default Passat edc15 dtc help
    Passat 1.9tdi edc15 29f400bt
    dtc off please
    p1855
    thanks in advance
    FapDpfservice's Avatar
    Sep 2021
    Quote Originally Posted by temur38 View Post
    dtc off please
    p1855
    thanks in advance
    you mod file.
    <a href="https://www.evc.de/en/check_evc_license.asp?k=JETn6EjRQpeE9y4%2fKKRgkQ%3 d%3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=JETn6EjRQpeE9y4%2fKK RgkQ%3d%3d"></a>
    temur38's Avatar
    Oct 2018
    Quote Originally Posted by FapDpfservice View Post
    you mod file.
    It doesn't work because checksum is not calculated. my programmer is not calculating checksum
    Jul 2010
    dtc and chks
  5. The Following User Says Thank You to sepistar For This Useful Post:
    temur38 (21st September, 2021)
  6. #5
    temur38's Avatar
    Oct 2018
    Quote Originally Posted by sepistar View Post
    dtc and chks
    it works thank you
