Your repaired file licho ...
Hi friends.
Can someone repair this error from volvo srs module?
TEMIC 30724045
MOTOROLA: 9S12DG128-1L40K MASK
SRS-CFFF Control Module. Internal Fault
SRS-0005 Power Supply From The Battery. Voltage Too Low
SRS-0003 PAD/ PAE Lamp Faulty Function
SRS-0091 Driver's Seat Belt Buckle. Current Outside The Permitted Range
SRS-0055 Front Left Side Impact Protection (SIPS) Bag. Resistance Too High
SRS-00A5 Switch For Airbag In The On Position. Current Outside The Permitted Range
SRS-0002 SRS Indicator Lamp. Signal Missing
SRS-00A9 Switch For Airbag In The Off Position. Current Outside The Permitted Range
SRS-00AB Switch For Passenger Airbag. Faulty Function
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
licho (20th September, 2021)
Like the man said, "rust never sleeps". But your pm box is full ...
Best regards.
Dragon
licho (20th September, 2021), robert1232 (20th September, 2021)
Thanks, this is good.
Check the box PM
