Can someone help me with immo off ECU M3.2
BOSCH: 0261203552/553
this car does not have a separate immo unit, immo in the instrument panel
I attach the two files.
Thank you
Thank you
THANKS + REP if I help you
need help
now my goal is to buy xp-005
who will help?
Does anyone have a solution for 27c010?
I tried many solutions with 24c02, everything works on the table, adaptation channel 91 = 1, it does not work on the car,
there is no separate immo block, immo in the dashboard - I cannot remove the immo block, do I need to cut off the k-line?
have in channel 91 - 4
Why are you doing off.....add keys and job done
Swap ECU also easy......
need help
who will help?
Everything works! The car is far away and I saw only the ecu before and after installation, today I myself came to the car and installed the unit, first started the car without a dashboard - the car started and worked - ok!
Then I installed the instrument panel and started it again - the file is working - the auto starts and works.
Channel 91 has 1
I can't imagine what happened before)
Regards
eprst (22nd September, 2021)
eprst (23rd September, 2021)
