the odometer stored in ZGW when car was in service.
Anybody test this with newer DAS?
One thing interesting is how it flash only assistent memory without that you loose all car data inside like equipment?
Thanks for sharing this DAS Dev. procedure......
I was wondering if is possible to wipe out all the services and then create the ones I wanted to show or with the DEV mode there is an option to do selective erasing of those services.
Thanks!!
Axel
Well it worked for me thanks
I have tray this procedure on W211 and is no working, nothings happen, car still have service history
it working,
have you after download
reset ecu?
I tried it with DAS 11.2010 and it's not working...
I'll test it with DAS 05.2009and I'll report.
How long is the programing proccess? When I click yes to programm, in less than a second DAS says that programming is OK. I reset ZGW but service data are still there.
I tried it and it works, now all i need is a way of remaking the service intervals , anyone knows how to do that ?
How to Reset Assyst
This will invalidate your warranty, if you have any leftTurn the key to position 2 in the ignition lock and immediately press
button 000.0 twice within the space of one second.
Turn the key to position 0 in the ignition lock.
Press and hold button 000.0 Turn the key to position 2 in the
ignition lock. Keep button 000.0 pressed.
Service message with current remaining distance or remaining time
appears.
After about 10 seconds, an acoustic signal will sound and the service
display with the new starting distance or starting time appears for
about 10 seconds.
Release button 000.0
Master Computer Engineer, A+, Network+, MCP 4/2k/2k3, MCSA/MCSE 2k/2k3, MCTS, MCITP Enterprise Administrator, Microsoft Certified Trainer/Systems Engineer, Brainbench, ICDL and starting Ph.D.
Col19 (13th November, 2019)
Hello! How to remove in the Command 211.026 2005 Event log. Thanks.
test its ok working
