test......
Hello . I need to repair Passat B6 ccm dump . Car has security acces time 255 min , and don t accept pin . After security time has passes , ccm refuse to accept the pin .
I have the correct pin (15477) . VIN is ok , but i have 0 key adapted , and i can t adapt old keys because ccm rfuse to accept pin . I think the eeprom is corrputed . Anybody can help me ?
test......
@esxo , thank you very much , but your dump don t work ... same problem ...
I forgot to mention ... on 25-immo i have 8 permanent errors ...
01176 - key no signal/communication
02823- requrements for locking the steering collumn lock not met
02827 - wake up request via ESP
02861- electronic steering collumn lock check sum error
02812- supply voltage ( terminal 30) for ESCL
02815- STEERING COLUMN lock - supply voltage for locking motor
02811- control module for electronic steering collumn lock (j764)
I can t delete this error codes !
I have a OEM NEW ESCL , but i can t adapt because ccm not accept pin code .
I replace IGNITION SWITCH and CCM (immo) module , but same problem , 8 errors , 0 adapted key , refuse to accept pin.
ALL FUSES ARE OK !
Any ideas ?
This might be of some help to you, a clue perhaps.
IF YOU ARE SENDING ME PM AND ASKING FOR PASSWORD WITHOUT TELLING ME WHERE THE LINK IS HERE, I WILL DELETE THE PM !!
