Results 1 to 3 of 3
    Nov 2017
    Default CAN Sniff / Log Porsche Cayenne 2005
    i got PCM2.1 E1 RDW (7L5035192A), Gateway, Instrumentcluster on Bench.
    PCM goes on, i can send via can remotecontrol commands and it works.
    But the front buttons auf the unit has no function.
    i thought there must be some can information to let them work.
    In car the PCM works fine.
    Has someone can bus log from comfort or navi can?
    See attached screenshot
    gapco's Avatar
    Jan 2012
    Johannesburg,South Africa
    Are you trying to turn the PCM on ? If this is the case there is no need to have gateway and instrument cluster connected. What the PCM needs is only the KL 15 (ignition on ) CANBUS message.
  3. The Following User Says Thank You to gapco For This Useful Post:
    username0815 (27th September, 2021)
    Nov 2017
    Quote Originally Posted by gapco View Post
    Thanks for your Answer, the PCM goes on with only +B on my bench, but after that, the volume control works. I cannot use any other buttons at Frontpanel. Do you have some Canbus Msg to simulate igniton on signal?
