Results 1 to 4 of 4
    Feb 2018
    Default i need a pin code instrument cluster
    Dec 2011
    Germany
    Default Pin code
    HI mate Try
    Feb 2018
    I read it with vag can commander 1.4 and the pin also shows 5581 but when I go with vcds it will not accept that code, does it have anything to do with a non-original cd radio, should I unplug it from the power supply and then try it, or that pin cod is not correct
    Aug 2015
    Latvia
    Hi, code is OK, in VCDS you must enter ,,05581". check for lock time in measuring blocks too.
