Results 1 to 13 of 13
Hybrid View
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    do a quick search on here mate, a good bit of info. And if you still need help I will help you out. I have a 910 myself. It's not too hard.
    DK Veteran m9g's Avatar
    Dec 2009
    Hi can you give me a hint on what to search for as I have tried various searches but nothing seems to come up
    Regards
    M9G
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    will do... you need
    the map western and central Europe 840.2562 Western_and_Central_Europe_840_2562 by Protect My Links . Com can you see this link?
    meta file from my downloads Digital Kaos - Downloads - meta.txt
    an activator easy use tools from my downloads too Digital Kaos - Downloads - Easy use tools
    Altho I have never used this myself.
    I am assuming your navcore is 7. something? you will need a 8 or 9. something to run your new map, I am using 9.024.
    you will need a few cans of stella for your new friend here.
    I have just got a new puter (do you like it? its shiny) so most of my old stuff is on my ~~~~ed puter, I will try get you all the files you need, maybe not tonight tho... homebrew is kicking in.
    Dec 2009
    hehehe cheers, appreciate it
    M9G
    Dec 2009
    I'm lost now, froze the 910, luckily found the reset on the back of the unit, phew!!!!!, havnt got a clue what i'm doing.
    Does anyone know of a complete step by step?
    Would be appreciated
    Regards
    M9G
    Dec 2009
    Right heres what I have......
    Western.Europe.v8.40.2562 map
    also have a meta called the same as the map
    SE_Navcore.8.410.1218
    tt8_keygen2
    Easyusetools
    Is this right? and what do I do with it please?
    Regards
    M9G
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    Try this prog if you can't get to grips with easy use tools
    Digital Kaos - Downloads - Easy activator
    I am assuming now your Navcore is all ok? it running, but no maps?
    For your Maps..
    Use the prog above to crack your map.. As far as I can see, it is quite straigh forward, just enter the details what it asks you for. You have the relevent bits, ie Map, meta.txt file, user id... the keygen is in the program itself.
