Hi pls help mi a need dpf additive off for ecu ford fucos 1.6 tdci thank you advance
Here is fully manual solution for you. Regards!
Thanks my friend for the help, I will try it and give you the result
Password bro
tarikprog (2nd October, 2021)
password bro thank yo advance
No workin my freind
Good evening, my friend, I forgive you. Your file is working successfully. The problem is that I did not remove the cable additive. Now, there is a solution to something. All right. Your file is working fine. Thank you for your help.
Good evening, my friend, I forgive you. Your file is working successfully. The problem is that I did not remove the cable additive. Now, there is a solution to something. All right. Your file is working fine. Thank you for your help. for your help.
