As far as I know, I will try to answer the questions in order:
- I assume that you can remove the physical module, then join the wires on pins 35, 36, 37 and 38 (depending on the equipment maintained on the car) and now access all the modules on the Low Speed CAN bus (CIM, UEC, REC, Display , Instruments, TPMS, AC) to program in each Airbag module as not present;
- I do not see the meaning of the ABS module, as long as you will not be able to meet all its conditions. As long as you want to simulate the pulses from the sensors on the wheels, the speeds declared by these simulators will be inconsistent with the actual speeds of each wheel correlated with the steering wheel angle, so that no function on the ABS module is functional, moreover, you will wake up with aberrant reactions from ESP;
- traction control I think you find it on both the ECM and the ABS (maybe on the Instruments), when you operate a modification, you have to do it in all the modules involved in that function, otherwise there are no correlations;
- almost every function has its specifics, strictly for the back doors, you just have to keep the contact for the door closed and everything will be ok;
- if you have air conditioning with manual control (from zafira), it will be relatively simple, but if you have air conditioning with automatic control, it gets a little more complicated, you may have to improvise something. In principle we have the schemes (you can find them in TIS), if you don't have them, we can help you with what you need;
- I have no idea about immo off on that ECU, but I would try not to do that, as long as possible in the original configuration. A colleague who knows about an immo off may also intervene;
- Basically, if you have the ambition to make the changes correctly, I think you will not have problems with lights on in the dash, and in the worst case, strictly to pass the checks, you can cover those areas with opaque tape on the side inside the instrument foil.
Good luck and keep us posted, I like the project.
