Please up.
Someone can check if the FAP is correctly removed? After every 150km the regen start (check with faplite). I don't have smoke but the change of the butterfly (in this engine during fap regen the intercooler is bypassed) is evident and the turbo reduce the power (during drive i have a bit esitation and shaking and it is very nuissance). I tried ADS but same result (but i don't have DTC). I tried to disconnect temperature sensor fap, additive, egr, diffential pressure...same result. One file is the original and other with ADS Remover 2017. Thanks.
Edit: the car is used and i don't have the original map with fap and egr.
Please up.
