I need reliable EGR&DPF OFF solution for this STAGE 1 of my VW mk6. Unfortunately, previous solutions didn't work well.
Hope this works well.
Which software did you use for this action?
if it doesn't work i can do it with winols.
I must ask him that because solutions with Volta, ADS DPF EGR don't work for this ECUAll I want is reliable solution where all DTC are turned off...
His solution doesn't work I need another one![]()
Here is your file with DPF&EGR OFF
Please, click thanks and reputation button and write to me on PM i will send you the password.
Greetings.
lyesdiag1965 (10th October, 2021), Smart66 (9th October, 2021)
Did you turn off all DTC for sensors?
I did what I need, upload and check: Let me know if it works properly
Next solution please!
Hello, What is problem here? Why ask for new file off? same DTC error , rigenerate?
File service, Custom Remapping, stage 1 & 2 dyno tested.
Petrol + Diesel
Adblue dpf egr Only tested working solutions.
Use thanks and Rep if my help was helpfull.
OK This ecu is simple to do dpf egr, surely if it does not start you have another problem it is not the mod file.
Petrol + Diesel
Mate, it can start with original file so it isn't ECU issue![]()
