Results 1 to 6 of 6
    DeLuXe's Avatar
    Mar 2019
    Default Volvo DIM - Arduino Uno, help please
    I am trying to learn little about arduino. I am trying to light up Volvo DIM with Arduino Uno and a MCP2515 CAN Shield.
    The open code is available on Github. But I have tried in almost every way but I get a error code trying to upload the "CanLogReplayer" but I dont get error code when trying to upload "DimSimulator".
    "CANLogReplayer:28:10: error: 'SerialUSB' was not declared in this scope
       while(!SerialUSB); //Prevents messages from being skipped because the arduino passes them before the serial connection is initialized.
    Desktop\VOLVO DIM\VolvoDIM-master\CANLogReplayer\CANLogReplayer.ino:28:10: note: suggested alternative: 'Serial'
              Serial
    Using library MCP2515_lib-master in folder: C:\Program Files (x86)\Arduino\libraries\MCP2515_lib-master (legacy)
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    Using library SD at version 1.2.4 in folder: C:\Program Files (x86)\Arduino\libraries\SD
    exit status 1
    I'm using Andrew Gabler code on Github.
    Anyone with experience that can guide me on this please?
    Thank you,
    Best regards,
    DeLuXe
    Sharing is carying. Please press Thanks + Rep Button if my post is helpful
    Nov 2015
    SerialUSB is for Arduino DUE and those with hardware USB. Ordinar Arduino has Serial
    "thanks" if i helped you is really appreciated
    DeLuXe's Avatar
    Mar 2019
    Thanks for your reply.
    According to manual (little that exist anyway) it should work with Arduino Uno and the Can shield I have.
    Here is the DimSimulator file code
    #include <mcp_can_dfs.h>#include <mcp_can.h>
    #include <SPI.h>
    #include <math.h>
    #include <time.h>
    /*SAMD core*/
    #ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
    #define SERIAL SerialUSB
    #else
    #endif
    // the cs pin of the version after v1.1 is default to D9
    // v0.9b and v1.0 is default D10
    //9 = Arduino UNO CAN Shield
    //const int SPI_CS_PIN = 9;
    //3 = Arduino MKR CAN Shield
    const int SPI_CS_PIN = 10;
    MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
    int genCnt = 0;
    int cnt = 0;
    int listLen = 10;
    int carConCnt = 0;
    int configCnt = 0;
    int blinkerInterval = 0;
    bool leftBlinker = false, rightBlinker = false;
    unsigned char stmp[8] = {0, 0, 0, 0, 0, 0, 0, 0};
    unsigned long address;
    unsigned long addrLi[10] = {0x217FFC, 0x2803008, 0x3C01428, 0x381526C, 0x3600008, 0xA10408, 0x2006428, 0x1A0600A, 0x2616CFC, 0x1017FFC};
       addrLi[0] = Speed/KeepAlive
       addrLi[1] = RPM/Backlights
       addrLi[2] = Coolant/OutdoorTemp
       addrLi[3] = Time/GasTank
       addrLi[4] = Brakes Keep alive?
       addrLi[5] = Blinker
       addrLi[6] = Anti-Skid
       addrLi[7] = Aibag Light
       addrLi[8] = 4C Error
       addrLi[9] = Car Config
    //Refer to Excel Sheets for info about data values.
    unsigned char defaultData[10][8] = {
      {0x01, 0x4B, 0x00, 0xD8, 0xF0, 0x58, 0x00, 0x00}, //0, Speed/KeepAlive , 0x217FFC
      {0xFF, 0xE1, 0xFF, 0xF0, 0xFF, 0xCF, 0x00, 0x00}, //1, RPM/Backlights , 0x2803008
      {0xC0, 0x80, 0x51, 0x89, 0x0D, 0xD4, 0x00, 0x00}, //2, Coolant/OutdoorTemp , 0x3C01428
      {0x00, 0x01, 0x05, 0xBC, 0x05, 0xA0, 0x40, 0x40}, //3, Time/GasTank , 0x381526C
      {0x00, 0x00, 0xB0, 0x60, 0x30, 0x00, 0x00, 0x00}, //4, Brake system Keep alive , 0x3600008
      {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, //5, Blinker , 0xA10408
      {0x01, 0xE3, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00}, //6, Anti-Skid , 0x2006428
      {0x00, 0x00, 0x00, 0x00, 0x00, 0xBE, 0x49, 0x00}, //7, Aibag Light , 0x1A0600A
      {0x0B, 0x42, 0x00, 0x00, 0xFD, 0x1F, 0x00, 0xFF}, //8, 4C keep alive / prevent error , 0x2616CFC
      {0x01, 0x0F, 0xF7, 0xFA, 0x00, 0x00, 0x00, 0xC0}  //9, Car Config default , 0x1017FFC
    //Sets the data for what the car is equiped with.
    //Taken from a 2007 M66 SR with Climate package, rear parking sensors, no nav.
    unsigned char carConfigData[16][8] = {
      {0x10, 0x10, 0x01, 0x03, 0x02, 0x01, 0x00, 0x01},
      {0x11, 0x18, 0x05, 0x05, 0x02, 0x03, 0x01, 0x05},
      {0x12, 0x03, 0x02, 0x02, 0x01, 0x02, 0x05, 0x01},
      {0x13, 0x01, 0x01, 0x01, 0x02, 0x02, 0x01, 0x04},
      {0x14, 0x04, 0x01, 0x02, 0x01, 0x02, 0x03, 0x11},
      {0x15, 0x15, 0x03, 0x02, 0x02, 0x01, 0x01, 0x01},
      {0x16, 0x02, 0x62, 0x02, 0x01, 0x02, 0x01, 0x02},
      {0x17, 0x01, 0x02, 0x02, 0x01, 0x03, 0x03, 0x01},
      {0x18, 0x01, 0x05, 0x03, 0x03, 0x12, 0x04, 0x04},
      {0x19, 0x11, 0x02, 0x10, 0x01, 0x05, 0x01, 0x02},
      {0x1A, 0x01, 0x02, 0x01, 0x04, 0x01, 0x01, 0x03},
      {0x1B, 0x01, 0x02, 0x10, 0x01, 0x01, 0x01, 0x01},
      {0x1C, 0x01, 0x04, 0x01, 0x03, 0x01, 0x06, 0x01},
      {0x1D, 0x04, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01},
      {0x1E, 0x01, 0x03, 0x01, 0x01, 0x01, 0x01, 0x01},
      {0x1F, 0x01, 0x02, 0x05, 0x02, 0x02, 0x22, 0x01}
       Time is 0-1440
       every mumber is a minute
       24 hours
       AM - 0- 719
       PM - 720-1440
    void updateTime(int inputTime)
      if (inputTime >= 0 && inputTime <= 1440) {
        int b4;
        for (int i = 0; i < 6; i++)
          if (inputTime >= (i * 256) && inputTime < ((i + 1) * 256))
            b4 = i;
        int b5 = inputTime - (b4 * 256);
        defaultData[3][4] = b4;
        defaultData[3][5] = b5;
      else
        //SERIAL.println("Not a valid time");
       input time as 2 2 didgit numbers 12, 43 = 12:43, 4, 24 = 4:24
       AM = 1 is AM
       Am = 0 is PM
       returns time in updateTime format 0 - 1440
    int clockToDecimal(int hour, int minute, int AM)
      if ((hour >= 0 && hour <= 12) && (minute >= 0 && minute < 60) && (AM == 1 || AM == 0)) {
        if (AM)
          if (hour == 12)
            return (minute);
          else
            return ((hour * 60) + minute);
        return ((hour * 60) + minute) + 720;
      else
        return 0;
       Initialization data from logs for SRS sytem
    void initSRS()
      unsigned char temp[8] = {0xC0, 0x0, 0x0, 0x0, 0x0, 0xBC, 0xDB, 0x80};
      unsigned long tempAddr = 0x1A0600A;
      CAN.sendMsgBuf(tempAddr, 1, 8, temp);
      delay(15);
      temp[0] = 0x0;
      delay(15);
      temp[0] = 0xC0;
      temp[6] = 0xC9;
      delay(15);
      temp[0] = 0x80;
       Generates a value for the SRS message.
       Couldn't detect a pattern from my logs on the meaning of the first byte.
       First byte is decided semi-randomly and is selected based on occureance in the logs.
    void genSRS(long address, byte stmp[])
      int randomNum = random(0, 794);
      if (randomNum >= 0 && randomNum < 180)
        stmp[0] = (char)0x40;
      else if (randomNum >= 180 && randomNum < 370)
        stmp[0] = (char)0xC0;
      else if (randomNum >= 370 && randomNum < 575)
        stmp[0] = (char)0x0;
      else if (randomNum >= 575 && randomNum < 794)
        stmp[0] = (char)0x80;
      CAN.sendMsgBuf(address, 1, 8, stmp);
      delay(15);
       Init 4C message
    void init4C()
      unsigned char temp[8] = {0x09, 042, 0x0, 0x0, 0x0, 0x50, 0x00, 0x00};
      CAN.sendMsgBuf(0x2616CFC, 1, 8, temp);
      delay(15);
      delay(15);
      temp[0] = 0x0B;
      delay(15);
      temp[0] = 0x0B;
        Generate the car config. May be mileage from CEM, not sure.
        Sets last 2 bytes randomly based on random occurance in the logs.
    void genCC(long address, byte stmp[])
      int randomNum = random(0, 7);
      if (randomNum > 3)
        stmp[6] = (char)0xFF;
        stmp[7] = (char)0xF3;
      delay(15);
       Generates random values for temp message
    void genTemp(long address, byte stmp[]) {
      int randomNum = random(0, 133);
      if (randomNum < 16)
        stmp[0] = (char)0x00;
      else if (randomNum >= 16 && randomNum < 41)
      else if (randomNum >= 41 && randomNum < 76)
      else if (randomNum >= 76 && randomNum < 133)
      if (randomNum < 76) {
        stmp[1] = (char)0x80;
      else
        stmp[1] = (char)0x00;
      randomNum = random(0, 105);
      if (randomNum < 7)
        stmp[2] = (char)0x11;
      else if (randomNum >= 7 && randomNum < 15)
        stmp[2] = (char)0x71;
      else if (randomNum >= 15 && randomNum < 25)
        stmp[2] = (char)0x61;
      else if (randomNum >= 25 && randomNum < 60)
        stmp[2] = (char)0x51;
      else if (randomNum >= 60 && randomNum < 105)
        stmp[2] = (char)0x41;
      delay(15);
       Convert Celsius to Fahrenheit
    double celsToFahr(double temp) {
      return ((temp * (9 / 5)) + 32);
       Set the digital outdoor temperature with fahrenheit input
       (Will always display on dim in fahrenheit)
    void setOutdoorTemp(int oTemp) {
      if (!(oTemp < -49 || oTemp > 176))
        if (oTemp > -50 && oTemp <= 32) {
          defaultData[2][4] = 0x0D;
          defaultData[2][5] = ceil((oTemp + 83) * 2.21);
        else if (oTemp > 32 && oTemp <= 146)
          defaultData[2][4] = 0x0E;
          defaultData[2][5] = ceil((oTemp - 33) * 2.25);
        else if (oTemp > 146 && oTemp < 177)
          defaultData[2][4] = 0x0F;
          defaultData[2][5] = ceil((oTemp - 147) * 2.20);
      else
        //SERIAL.println("Temp out of range");
       Sets the coolant gauge from low to high
       Accepts value 0-100 low to high.
    void setCoolantGauge(int range) {
      if (range >= 0 && range <= 55 ) {
        defaultData[2][3] = range + 88;
      else if (range > 55  && range <= 100 ) {
        //upper limit scales very slowly.
        //This calculation makes it fit the 0-100 scale much better.
        defaultData[2][3] = ceil((range - 55) * .333) + 173;
      else
        //SERIAL.println("Value out of range");
       Sets the speed in mph
    void setCarSpeed(int carSpeed) {
      if (carSpeed >= 0 && carSpeed <= 160) {
        if (carSpeed >= 0 && carSpeed <= 40) {
          defaultData[0][5] = 0x58;
          defaultData[0][6] = round(carSpeed * 6.375);
        else if (carSpeed > 40 && carSpeed <= 80)
          defaultData[0][5] = 0x59;
        else if (carSpeed > 80 && carSpeed <= 120)
          defaultData[0][5] = 0x5A;
        else if (carSpeed > 120 && carSpeed <= 160)
          defaultData[0][5] = 0x5B;
      else
        //SERIAL.println("Speed out of range");
       Set gas gauge level 0-100
    void setGasLevel(int level) {
      if (level >= 0 && level <= 100) {
        defaultData[3][6] = round(level * .64 );
        defaultData[3][7] = round(level * .64 );
      else
        //SERIAL.println("Gas level out of range");
       Set RPMs 502-8000
       Will not match gauge precicely, but close as can be.
       501 and lower = 0x01 which is a no go.
       Very weird system for rpm it counts 0-255 by increments of 32 and rolls over
    void setRpm(int rpm) {
      if (rpm > 501 && rpm <= 8000) {
        defaultData[1][6] = floor((rpm * .031875) / 32) * 32  + floor((rpm * .031875) / 8);
      else
        //SERIAL.println("RPM out of range");
       Set Overhead led brightness 0-256
    void setOverheadBrightness(int value) {
      if (value >= 0 && value <= 256) {
        defaultData[1][2] = value;
      else
      Set LCD brightness 0-256
    void setLcdBrightness(int value) {
        defaultData[1][4] = round(value / 32);
      else
      Set brightness of all lights
    void setTotalBrightness(int value) {
        setLcdBrightness(value);
        setOverheadBrightness(value);
      else
       Set left blinker to ON or OFF
    void setLeftBlinker(bool state) {
      if (state) {
        defaultData[5][7] = 0x0A;
      } else {
        defaultData[5][7] = 0x0;
      leftBlinker = state;
       Set blink right to ON or OFF
    void setRightBlinker(bool state) {
      if (state) {
        defaultData[5][7] = 0x0C;
      } else {
      rightBlinker = state;
    void genBlinking(long address, byte stmp[], bool isBlinking, int interval, int blinkSpeed) {
      int blinkRatio = 7;
      if (blinkSpeed == 0) {
        blinkRatio = 5;
      } else if (blinkSpeed == 2) {
        blinkRatio = 15;
      } else if (blinkSpeed == 3) {
        blinkRatio = 50;
      if (isBlinking && (interval % blinkRatio == 0)) {
        int prevState = 0;
        if (leftBlinker && rightBlinker) {
          if (defaultData[5][7] == 0x0E) {
            defaultData[5][7] = 0x08;
          } else {
            defaultData[5][7] = 0x0E;
          stmp[7] = defaultData[5][7];
          delay(15);
        } else {
          if (defaultData[5][7] == 0x0A || defaultData[5][7] == 0x0C) {
            prevState = 1;
          //blinks left blinker
          if (leftBlinker) {
            if (prevState == 1) {
            } else {
            delay(15);
          //blinks right blinker
          if (rightBlinker) {
            } else {
            delay(15);
    void setup()
      SERIAL.begin(115200);
      //while(!SerialUSB); //Serial monitor must be open for program to run.
      randomSeed(analogRead(0));
      while (CAN_OK != CAN.begin(CAN_125KBPS,MCP_8MHz)) // init can bus : baudrate = 500k
        SERIAL.println("CAN BUS Shield init fail");
        SERIAL.println("Init CAN BUS Shield again");
        delay(100);
      SERIAL.println("CAN BUS Shield init ok!");
      initSRS();
      init4C();
      //updateTime(clockToDecimal(random(0, 13), random(0, 60), random(0,2)));
      //(random(-49,177));
      //setCoolantGauge(random(0,100));
      //setCarSpeed(random(0,160));
      //setGasLevel(random(0,100));
      //setRpm(random(502,8000));
      //setTotalBrightness(random(0,257));
      updateTime(clockToDecimal(1, 30, 1));
      setOutdoorTemp(72);
      setCoolantGauge(82);
      setCarSpeed(72);
      setGasLevel(90);
      setRpm(3400);
      setTotalBrightness(256);
      //setLeftBlinker(true);
      setRightBlinker(true);
       Main message organization
    void simDim() {
      address = addrLi[cnt];
      for (int i = 0; i < 8; i++)
        stmp[i] = defaultData[cnt][i];
      if (address == 0x1A0600A)
        genSRS(address, stmp);
      else if (address == 0x3C01428)
        genTemp(address, stmp);
      else if (address == 0x1017FFC)
        if (carConCnt % 12 == 1)
            stmp[i] = carConfigData[configCnt][i];
          configCnt++;
        else
          genCC(address, stmp);
      else if (address == 0xA10408) {
        genBlinking(address, stmp, true, blinkerInterval, 1);
      else
        //SERIAL.println(address);
        delay(15); // send data per 15ms
      cnt++;
      blinkerInterval++;
      if (cnt == listLen)
        if (configCnt >= 16)
          carConCnt = 0;
        else
          carConCnt++;
        cnt = 0;
      if (blinkerInterval >= 50) {
    void loop()
      simDim();
    // END FILE
    Cant understand really where to problem should be. I give speedometer +12v and gnd from external source so that I dont fry the Arduino Uno. Also CAN H + L.
    Best regards,
    DeLuXe
    Nov 2015
    The compiler does not know about SerialUSB when compiled to Uno or Nano. Just comment it out or change for "Serial".
    DeLuXe's Avatar
    Mar 2019
    Thanks again for your reply.
    If I blackout/put comment on these two lines:
    #ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE// #define SERIAL SerialUSB
    // #else
    #endif
    Then I get error:
    Arduino: 1.8.16 (Windows 10), Board: "Arduino Uno"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\XXX\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\XXX\AppData\Local\Temp\arduino_build_210258 -warnings=none -build-cache C:\Users\XXX\AppData\Local\Temp\arduino_cache_518408 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\XXX\Desktop\VOLVO DIM\VolvoDIM-master\My file\DimSimulator\DimSimulator.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\XXX\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\XXX\AppData\Local\Temp\arduino_build_210258 -warnings=none -build-cache C:\Users\XXX\AppData\Local\Temp\arduino_cache_518408 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\XXX\Desktop\VOLVO DIM\VolvoDIM-master\My file\DimSimulator\DimSimulator.ino
    Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp" -o nul
    Alternatives for mcp_can_dfs.h: [MCP2515_lib-master]
    ResolveLibrary(mcp_can_dfs.h)
      -> candidates: [MCP2515_lib-master]
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp" -o nul
    Alternatives for SPI.h: [SPI@1.0]
    ResolveLibrary(SPI.h)
      -> candidates: [SPI@1.0]
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master\\mcp_can.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp" -o "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\MCP2515_lib-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp" -o "C:\\Users\\XXX\\AppData\\Local\\Temp\\arduino_build_210258\\sketch\\DimSimulator.ino.cpp.o"
    C:\Users\XXX\Desktop\VOLVO DIM\VolvoDIM-master\My file\DimSimulator\DimSimulator.ino: In function 'void setup()':
    DimSimulator:488:10: error: request for member 'begin' in '0', which is of non-class type 'int'
    DimSimulator:494:12: error: request for member 'println' in '0', which is of non-class type 'int'
    DimSimulator:495:12: error: request for member 'println' in '0', which is of non-class type 'int'
    DimSimulator:498:10: error: request for member 'println' in '0', which is of non-class type 'int'
    exit status 1
    DeLuXe's Avatar
    Mar 2019
    Have no idea how to proceed here after...
    Any help please? This is only an experiment to try if this works
    Best regards,
    DeLuXe
