Results 1 to 10 of 10
Thread: about ELV MK6
    Jun 2014
    Default about ELV MK6
    Hi, did any body know which tool can read ELV for mk6? and is there any pcb soldering wire location point to know how to read the ELV?, thank you in advance...
    rm23's Avatar
    UK
    mk6 of what? please give more details and someone will help you..
  3. The Following User Says Thank You to rm23 For This Useful Post:
    pouleddy (14th October, 2021)
    Jun 2014
    Quote Originally Posted by rm23 View Post
    Hi, vw golf6 2012 its a keyless function, need to read direct by soldering wires to pcb of ELV , i need to know which tool can read this elv on the bench, and if any manual to know where is the points on pcb of elv, to solder & ready to read/write . thank you in advance...
  5. The Following User Says Thank You to pouleddy For This Useful Post:
    rm23 (14th October, 2021)
  6. #4
    Oct 2014
    Netherlands
    I haven't seen anything yet about reading data from these ELVs.
    I just looked at a picture of such pcb and I see cpu NEC/Renesas 70F3624.
    This cpu has got both code flash and data flash.
    If the cpu is locked then it will be very hard to read it, but maybe it is unlocked....
  7. The Following User Says Thank You to H2Deetoo For This Useful Post:
    pouleddy (17th October, 2021)
  8. #5
    Jun 2014
    Quote Originally Posted by H2Deetoo View Post
    thanks for your info, maybe this elv we can read by vvdiprog by soldering wires direct to processor, but i want to try to know if there is other easy way same as reading the ELV of Audi A5 Q5 by soldering wires to PCB of ELV...
  9. #6
    Hi do you want to read the ELV?
    Just curious...
  10. #7
    Jun 2014
    Quote Originally Posted by cristo_844 View Post
    Just curious...
    yes, why we can't read this elv?
  11. #8
    Dont know...
    I retrieve immo data from the cluster or ECU in donor car then adapt used ELV!
  12. #9
    Jun 2014
    Dont know...
    yes me to do that, but if you don't have donor ecu or cluster data and online account for odis, so for that i am trying if we can read the ELV on the bench, but i think its look the cpu of ELV locked as above which write me (H2Deetoo), so i am trying to get any positive solution...
  13. #10
    May 2024
    Quote Originally Posted by pouleddy View Post
    hello
    very old post, but im giving a try..
    did you solved to read the 70F3624?
