Results 1 to 9 of 9
    Top Poster luisfm's Avatar
    Feb 2013
    Default Golf 4 tdi a need + power
    hi, can someone help me give a little more power to this Golf 4 tdi 6 speeds?
    I think that due to a fault in the past they changed the ecu unit for another one, which I'm not sure if it is the same reference as the one it had as standard.
    the car is good but I wish it had a little more power.
    Thank you
    gomku's Avatar
    May 2017
    Default golf
    Stage 1 for you. pass -> thx and rep pls pm
  3. The Following 2 Users Say Thank You to gomku For This Useful Post:
    31atom92 (17th October, 2021), luisfm (14th October, 2021)
    Feb 2013
    Quote Originally Posted by gomku View Post
    Thanks, I'll give it a try and tell you how it goes.
    Feb 2013
    I have tried and it has improved a lot. Thank you so much
    Aug 2019
    Quote Originally Posted by luisfm View Post
    Thank you
    if you need dyno tested file pm me
    gomku's Avatar
    May 2017
    You welcome
    gomku's Avatar
    May 2017
    Quote Originally Posted by labors View Post
    do you know this file is not tested in dyno?
    Aug 2019
    I don't see the problem , there was just no information in your post
  10. #9
    gomku's Avatar
    May 2017
    You are the one who thinks there is a problem. I prepared the file. You're the one who wanted to export the dyno file. you think my file is bad????
