Well, me
Sent from my iPhone using Tapatalk Pro
Well, me
Ok not an expert but I would definitely like to share what I learnt.
1. Magnifying glass or microscope would be a real plus to have around.
2. If you read around you will find that UART is generally referred to as one of that requires Rx and Tx to function
However this is not really true for Airbag modules you will need to power the module too plus a few other things.
3. Normal connections required
Rx
Tx
Vcc
Ground
Md0
Md1
Reset
4. Just look around for the pins from the net (easiest)
if not available look for the pins mentioned above from the MCU datasheet
5. Ground is probably the easiest to find
Vcc is the positive generally 5 Volts
Rx Tx Reset from datasheet
MDo Disconnect it from +5 volt supply (that's why you see the zero ohm resistor removed)
MD1 Connect it to +5 Volt supply (that's where you see bridging required)
MDo and MD1 also obtained from the datasheet
7. Of course sometimes there are pins where you can't follow from the MCU legs directly (then either desolder the MCU or use a multi meter to find the trace on the other side of the board.
8. Return the zero ohm resistor back in place Restore initial state of MDo and MD 1
9. Repair with solder mask the parts that was scratched on board
ollync (18th October, 2021)
Hope it was useful ollync.
Cutting off track leading to reset leg sometimes easier than lifting reset leg.
Absence of MD1 on progammers doesn't mean it's not going to work.
Someone no idea who on here slips single strand of wire under a leg hotair and lifts
