Results 1 to 6 of 6
    Nov 2016
    venezuela
    Default BMW 320i misfire problem
    hello friends i have bmw e90 320i 2007 and i am getting the following codes any suggestions?
    29D0 misfire Cylinder 4
    29CE misfire Cylinder 2
    Meat-Head's Avatar
    Start with. Compression test. Then. Cylinder leakage test
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    Stelaras26 (20th December, 2021)
    Nov 2016
    venezuela
    I will do what is indicated, and I will inform you of the results
    Oct 2021
    Does it has an igition coil for every cylinder? If yes, first change the ignition coils of the missfiring cylinders with the other ones. Then check, if the fault goes with'em. If yes, you have two bad ignition coils.
  6. #5
    May 2010
    Swap coils, erase codes, test engine.
    Rinse'n repeat.
    Spark plugs how many miles on them?
    Is it converted to LPG/CNG?
    ______
  7. #6
    Sep 2013
    figueres, SPAIN
    I had this problem some years ago...
    First failed some coils but later i’ve noticed a rough idle and some misfires. The problem was in valvetronic system.
    Problem was solved when i’ve replaced the hidraulic valve lifters and the intermediate levers of the valvetronic (very expensive).
    Also i had problems with valve seals, valve guides and valve seats.
    This engine was a nightmare for me
