Results 1 to 7 of 7
    Default VW GOLF VII GTE DQ400 HYBRID gearbox error 30097 – Transmission Fluid Pressure
    Hello for all.
    I have one issue with Golf GTE 2015 1.4 tsi gearbox DQ400E
    The car is come to workshop with this error 30097 Transmission Fluid Pressure, we change TCU we clone the original one result same error, we change vale body he work one day then again same problem. If some one can help me with some information i will appreciate and not just that.
    Thank you.
    Meat-Head's Avatar
    Can you drain the oil out and see if signs of glitter of metal disintegration
    Nov 2017
    Dobruja
    Did you try to change the gearbox liquid brand and put the correct volume in it? Check the overflow valve up ahead the gearbox to be free and moving slightly. Is important when hot liquid expands. Or leave the fluid stick checker a bit loose out and see if it changes.
    I change the oil but client h change the oil before. Don't see any. metal glitter.
    Thank you, if anything i can do more. Please let me know.
    Hi. I will try to do this. Thank you for help i will come with news.
    Quote Originally Posted by volodin69 View Post
    Thank you for advice I will try this. If anything you think i can do more please let me know.
    Thank you again.
    Oct 2012
    Quote Originally Posted by fane_81 View Post
    Thank you again.
    Did you solve this problem?
