    Member kody_2004's Avatar
    Pt
    Default EDC17C60 Peugeot 508
    Hello!!! to All
    Can someone help remove Adblue and Dpf from this ecu 0281032456.
    I try ran out of dtcs but still gives warning urea on dash
    scr- nox sensor- disable."KTAG Read"
    Thanks for help.
    Sep 2019
    ESPAŅA MADRID
    here I attach
    appreciates the work. a greeting(0281032456-EDC17C60-MAPS(_ADBLUE__DPF_)).rar
    no addys !!!
  3. The Following User Says Thank You to tecnicuadros For This Useful Post:
    kody_2004 (16th October, 2021)
    Mar 2016
    HI
    ADBLUE DPF OFF
    he ADblue pump an AdBlue module de disconnected
    The Additive pump Must be disconnected
    WARM REGARDS
  5. The Following User Says Thank You to samranisimo For This Useful Post:
  6. #4
    Dec 2015
    Kaja
    Hi contact me i do free
  7. The Following User Says Thank You to eggystar For This Useful Post:
  8. #5
    Pt
    Quote Originally Posted by samranisimo View Post
    HI
    ADBLUE DPF OFF
    WARM REGARDS
    Sorry but this solution has been tested always warning urea.
  9. #6
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Reset SCR And DPF With Original File, Then Disconnect Adblue ECU And Pump
    Pass In Pm
    Report Back
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  10. The Following 2 Users Say Thank You to momogsm For This Useful Post:
    kinketotua (17th October, 2021), kody_2004 (16th October, 2021)
