    Oct 2017
    Default Help rpm goes high
    Good day all, my nissan almera qg15 rpm goes high on changing gear. I actully dismantled the throttle body for a thorough cleaning and after mounting back i started experiencing high rpm which changing gear. Can someone help out. Thanks
    Rider667's Avatar
    Feb 2020
    my MC saddle
    Check for intake leak...vacuum leak..most of the time high rpm is caused by leaks in intake system...check for errors with some diagnose equipment,live data etc
    Oct 2017
    Quote Originally Posted by Rider667 View Post
    Thanks brother
    Sent from my LLD-L21 using Tapatalk
    fuzz1's Avatar
    Jul 2019
    What fault did you get after running diagnostic?
    Oct 2021
    also check egr valve if throttle body ok
    Aug 2016
    Check Crankcase Vent Valve .
