Results 1 to 7 of 7
    Sep 2008
    Exclamation Dreambox 500c,not opening channels!!!
    Hi to you all,
    flashed dreambox with dk_v1 as well as dk_v1.1,using Dresmup & Null serial cable.Then downloaded the Dreambox Keys off Rapidshare & did the Transfer using Flash FXP from PC to The Box which Showed all the keys being transfered,following the instruction on the forum.
    I shut down down the Box & restarted & went to sky sport 1,waited to clear.
    still no picture came up.
    I wonder, if I have to change Evocam 2.12 OR Change the Digital choas to Enigma at all.Any suggestion or help will be much appriciated!!
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    CAn take anyhting from a minute to 2 minutes to clear. If you have followed the instructions it should be working fine.
    Must be patient.
    Try again.
    Sep 2008
    Hi there,waited more than 5-6 minutes,still no joy!!
    Jul 2008
    cmd
    Then youve done something wrong somewhere mate.
    Try holding info for a few seconds the cam menu will come up restart the cam and see what happens.
    Doesnt need to be SS1 you try i usually have mines on bravo after an install.
    See what happens mate. Let us know.
    Sep 2008
    cam menu starts ok,but I just try Bravo channel,as well.
    Sep 2008
    Sorry,still no luck on Bravo!!
    Sep 2008
    Must go to work.will post this tomorrow,as well.
    Many thanks
