Reading MDF2 with ch341A: help with cable conection un Blaupunkt VWZ1F7F6
Results 1 to 10 of 10
    Oct 2021
    Default Reading MDF2 with ch341A: help with cable conection un Blaupunkt VWZ1F7F6
    Hello all. This is the label of my nav Radio form my Touareg.(MFD2) i wrote wrong in title, sorry)
    And this is the motherboard and how i put the cables to read the FIS.
    i think i m not sure if i did well..Someone could help me and correct me please? (i searched in forum bu tis soo bigger and i cant find this) Thanks for help.
    i need my code to unlock it but i m reading with errors, maybe is cause my cables config are wrong.
    Mar 2020
    in the field
    hello everything is in thread radio decode looks like 5-7v bad connection
    Oct 2021
    Hello, thanks for your answer, And what colour wire is bad connected in image i uploaded? Thanks again
    Mar 2020
    in the field
    what device are you reading this? upa 1.3 is good
    Oct 2021
    Hello, i m reading with ch341A programmer and Neoprogammer detected chip 24c64 (generic 24Cxx)
    Then, is very important to input the code when the radio is installed in the car?
    i will try with upa 1.3 too, thanks
    Mar 2020
    in the field
    it's probably too weak the programmer, it's better to skr ypt how to connect, you only need to lower the voltage 7v, you can enter the code on the table
  7. The Following User Says Thank You to pawl For This Useful Post:
    pelexat (20th October, 2021)
    fuzz1's Avatar
    Jul 2019
    Hi.
    7 volts?
    Why this voltage?
    Mar 2020
    in the field
    hi laboratory power supply
  10. #9
    fuzz1's Avatar
    Jul 2019
    Are you sure 7v? I may be wrong of course but never came across chips that require 7 v for cars
  11. #10
    Mar 2020
    in the field
    to read 24c32 you need to lower the voltage on the entire device the whole description is somewhere on the dk, now I do not have time to look for greetings
  12. The Following User Says Thank You to pawl For This Useful Post:
    fuzz1 (4th November, 2021)
