kappa1 (10th April, 2015)
Wrong dump ! U must read again, but really like 24C16.
thanks for the reply!
is read ok
conter on line 0000/A [89].... If I help you
kappa1 (13th April, 2015)
error dump, try to read it again, confirm friend
try 8100 but i 'not sure
but try it
did U try 9668?
9668;8100....no work
kappa1 (6th May, 2015)
2984;8429?
O.
Your dump is sh1t mate .... 64kb too big ......Try and read it again .....
if Z854 security>then> code:0148
Sounds about right it is a sh1t dump and now this post seems to be hacked by first timers copying original posts for code just to get a leach this post should be closed unless zvasile gets back and says it works. I don't mind helping out as I know this great forum has helped me out (even when I haven't asked) due to search and other posts I don't mind helping folk out. But some folk come for eurovox etc and see car section fair enough I can live with that that's why I came. But some folk want everything for free (as we all do ) but you need to give to get as far as I'm concerned Ill be the first to say I know he_haw about mileage correction but I could rebuild an engine faster than most members or mechanics (served my time doing it) I spend most of my time on this forum reading previous posts as noobs should. I came here to learn and if I can help out then I will if I cant then I'll ask for help but from reading posts there are some members I would take no advice from and others I wouldn't (NOOBS) and M_H_M.com yeah he has his (STRANGE) way of putting things but if you read between the lines he actually makes sense though he still thinks Edward are the best band he's ever seen.
Good code is 9668, but is too late for help.
