Results 1 to 5 of 5
    binariman's Avatar
    Apr 2014
    europe
    Default LVD edc16c39 p0601 p0401
    LVD 2500crd edc16c39
    help to remove this dtc p0601 p0401
    car is in safe mode
    please remove from 2 tables
    pike's Avatar
    Sep 2013
    DTC off not solved problem with safe mode
  3. The Following User Says Thank You to pike For This Useful Post:
    binariman (23rd October, 2021)
    binariman's Avatar
    Apr 2014
    europe
    Aha ok I did not know and what do you think is the solution.
    I thought that if I could remove dtc from the 2 tables that these usually have, it would be solved
    pike's Avatar
    Sep 2013
    P0601 - Internal Control Module Memory Checksum Error
    It original file?
  6. #5
    binariman's Avatar
    Apr 2014
    europe
    yes sure .Today I am going to try some things that have happened to me for this ecu.
    thanks alot
