Try dump, pass in pm
hello
i have porsche cayenne diesel 2012 bcm data damage with some one read write
i try write another working car bcm data & sync elv with avdi
immo adopt / elv / success
immo adopt / rear bcm / success
immo adopt / fornt bcm / fail bcoz need donar & install bcm data
below i attach mt all data
donar fornt bcm data
car orignal rear bcm data
car orignal elv data
car orignal ecu data
can any one sync forn bcm data
or help with online
after write your data nothing in car but after avdi immo adopt elv & elv lock unlock success but no igniton
so i do immo adopt front bcm , in this all process rear bcm fail
than i try only rear bcm than success but after that elv unlock stop
now error in rear bcm - 805208 - immobiliser authentication failed
[ ypiter] really heartily appreciate your help
hello
need small help
i have working car , some km away but i copy front bcm ,, rear bcm & elv
than write all data to fornt bcm , rear bcm & elv in dead car & make new key
now elv unlock & ignition came on but 1 sec , than message appear , key not removed
if any one know another module have some coding for igniton
remove getway & write vin manully
but in scannar porsche stebility control module have vin config errror
if i remove abs socket elv lock & unlock stop
i remove abs & check but no eeprom
what to do know
thanks to all of u
cardone & i have working all module data if any one need
please pass ! PLEASE PASS!!
Hi, can i have ur full data..
I have same problem
Key on 1 sec die
Show
Ignition key not remove
Thanks bro
