[QUOTE = crouchinggerbil; 4244886] Não, o firmware mais recente não funcionará em versões anteriores. [/ QUOTE]
Thanks , but in 2017 software i can use the single board with 1622 firmware?
[QUOTE = crouchinggerbil; 4244890] Você pode usar placa única sem problemas, mas no 17 você não pode usar o firmware 3201.
Experimente e veja com certeza. Dedique alguns minutos para descobrir por si mesmo[/ QUOTE]
thanks for the clarification, this will certainly be useful to more users..
crouchinggerbil (7th December, 2021)
2 first Torrent links are dead and last was exe having some weird somethingocean.exe file inside? so why not zip clear torrent link...
Thanks, much appreciated...
Gracias por el aporte, tengo un problema, me pide una dirección de correo electrónico y luego activación, ¿cómo no puedo pedir activación? o generador el para activarlo?
Gracias
It's already working, thanks
Hey.
For some reason i can't download the autocom.txt file with the links. Can you help or pm the link! Thanked in advance! <3
thks much...
sorry my bad speak english, my problem ,why dont download ? : Autocom 2020.23 VM EN by Fantomel Download Links.txt
Fantomel Links 1 and 2 still work, but isn't it better to use the normal version than VMWare?
Free activation.
https://www.digital-kaos.co.uk/forum...hlight=autocom
crouchinggerbil (12th January, 2022), Hellium (3rd February, 2022), kikis (12th January, 2022), stanislav georgiev (16th January, 2022)
It actually depends on how you want to use the program, and the required environment. If you have single computer, with right OS combination, you can install the App directly, and activate. However, if you have multiple computers or interfaces in your shop, and you are unsure if a new version will work or not with any interface, or want to be on the "safe" side, or simply have a "backup", you can have multiple virtual machines, each with a different App version (2017, 2018, 2020 and the like).
VMware is more involved, but gives greater flexibility.
Mario6 (3rd February, 2022)
Thanks, really nice work !
All links are dead.
Work god without SSD disk?
