Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 68
  1. #16
    Jan 2018
    EU
    Thanks to Fantomel Great Job work Nice slow but WORK
  2. #17
    Oct 2017
    Quote Originally Posted by DrGTO View Post
    Mines quite fast, it works really good. Your notebook hardware might be too slow to run a win7 vm in parallel with the host os. It needs quite a lot of ram and cpu power
  3. #18
    RS6's Avatar
    Feb 2021
    Can anyone help with a seemingly bricked VCI? after trying to update my single board to the latest firmware it no longer has the red lamps light up when connected to a car, they do however come on when the usb is connected to the laptop, software doesn't find the VCI any more, I tried reverting the firmware folder and no luck there
    (Old username Dik)
  4. #19
    Aug 2020
    Quote Originally Posted by RS6 View Post
    Can anyone help with a seemingly bricked VCI? after trying to update my single board to the latest firmware it no longer has the red lamps light up when connected to a car, they do however come on when the usb id connected to the laptop, software doesn't find the VCI any more, I tried reverting the firmware folder and no luck there
    Use wow to recover/downgrade firmware
    HaynesPro online + 2022.02a version available, message for where to get it!
  5. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    RS6 (18th November, 2021)
  6. #20
    RS6's Avatar
    Feb 2021
    Quote Originally Posted by crouchinggerbil View Post
    Thanks, got it working and managed to update firmware to 3200 via 2017 delphi however I can't get the firmware to copy over to the virtual machine version, seems to work with it but keep getting popup's saying firmware update needed, how do I get the firmware to copy over as copy/paste or drag/drop from windows doesn't work?
    (Old username Dik)
  7. The Following User Says Thank You to RS6 For This Useful Post:
    Meat-Head (30th November, 2021)
  8. #21
    Dec 2014
    PL
    Just use a pen drive. First rename ori FW to "Firmware 1622" then paste FW 3200.
  9. The Following User Says Thank You to Mario6 For This Useful Post:
    RS6 (25th November, 2021)
  10. #22
    RS6's Avatar
    Feb 2021
    Quote Originally Posted by Mario6 View Post
    So you can access the pen drive from the guest os?
    (Old username Dik)
  11. #23
    Dec 2014
    PL
    Yes.
    I have a VCI V 3.0 with dual PCB and changed the FW from 1622 to 1430. Works fine.
  12. The Following User Says Thank You to Mario6 For This Useful Post:
  13. #24
    Oct 2017
    Thank You very much however when i click on al links they download. Last link takes me to login page? (autocom file)
    Update: Weird when i opened page with inprivate browser it worked. Cache must be screwed!
  14. #25
    Oct 2017
    Default spoke too soon!
    Can someone confirm. I have a clone vci. It has two pcb boards inside i think. Should i be updating firmware?
  15. #26
    Dec 2014
    PL
    Quote Originally Posted by huseyine View Post
    If your VCI currently has FW 1622, you don't need to do anything. However, if you have a lower 1430, for example, the software will report an incorrect FW version.
  16. #27
    Dec 2019
    #fantomel
    Thankyou very much!
    It works on linux base too!
  17. #28
    Junior Member nfgrd's Avatar
    Apr 2017
    Tuga
    Mate Mario , One question, in 2017 software, can I use the single board with 1622 firmware?
    or can i also use the firmware 3200/3201?
  18. #29
    Apr 2017
    Tuga
  19. #30
    Aug 2020
    Quote Originally Posted by nfgrd View Post
    No, the newer firmware will not work on previous releases.
