Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    Feb 2010
    @drivergabriel, the key if made by Mercedes Germany will work perfectly well but if you use AK500 or any other, it will not engage the gear system as part of the key codes are stored in the 722.9 transmission system.
  2. #17
    Dec 2009
    I though the ak47 is a nick name of new tool
  3. #18
    Nov 2009
    workshop
    the exclusive Mercedes-Benz 722.9 solve computer gear shift control and running the computer authorized to global problems, global unique technology
  4. #19
    Senior Member drivergabriel's Avatar
    Aug 2009
    BUCURESTI
    Quote Originally Posted by sogaro View Post
    i know that. someone from here use merc commander from abritus? i am not 100% sure, but i think to buy avdi.
  5. #20
    Jan 2010
    Ecuador
    you will need this item Feature: New tool can programming new blank key with BIN file that's is generating using Dump Modify software .
    Feature Function:
    it communication with key via IR and RF in mercedes benz security protocol .( that's meaning you can use it for all type keys and if there is any new key with private mcu no problem )need only to update . The new Mercedes device working with small key (old and new) using in car since 1997 up to 2005 - without keyless system. You can program newkey (or used) in car and program old key if its not work more.You need read and program eeprom of CPU from Steering blocking module. Desolder and read via programmer two CPU from Electronic Ignition Control Module.Load these eeproms to program.Desolder NEC CPU from the key. Soldering it on the device , select the No. of key and program it. Solder all CPU on their places and start the car. You can program new keys without the car - only with EISand steering blocking module.You can read theese CPU with other programmer. new model small key is available programming all small key model for all years models W220 -W211 - W230 - W203 -W215 - W210 - W209.
  6. #21
    chakahafed's Avatar
    Dec 2009
    nouakchott
    Quote Originally Posted by BimmerGT1 View Post
    you will need this item Feature: New ter all CPU on their places and start the car. You can program new keys without the car - only with EISand steering blocking module.You can read theese CPU with other programmer. new model small key is available programming all small key model for all years models W220 -W211 - W230 - W203 -W215 - W210 - W209.
    I think you forget about renew the ECU
  7. #22
    gepakg's Avatar
    Feb 2010
    Serbia
    as i know in W164 EZS is nec mcu,not possible reading and makeing new keys
    regards Gepa
    Quote Originally Posted by chakahafed View Post
  8. #23
    Dec 2009
    Do you talk about, EIS?
    Quote Originally Posted by gepakg View Post
    regards Gepa
  9. #24
    Sep 2009
    722.9 7G .I CAN MAKE IT NEW .
  10. #25
    Dec 2009
    Really? How?
    Quote Originally Posted by riospeed View Post
  11. #26
    Sep 2009
    on the table in my work
  12. #27
    Sep 2009
    you can do this RIOSPEED FOR ALL the 722.9 transmission system. THIS FOR SALE
  13. #28
    Sep 2009
    What you need to program key's in W164/X164/W221 :
    1. put key hash'es in EZS - possible only for "old" 164 EZS based on S12 motorola/freescale MCU, but after 2006/6 NEC V850 (palermo,havana, cuba, milano mask sets) used in EZS - we haven't solution's for this CPU reprogramming - only replace and then personalize with "orange" key...
    2. put key hash'es in engine ECU (ME 9.7, Delfi CDI5 ....) or "renew" and then personalize and make SCN with "online" , code injector's in CDI, learn another functions.....
    3. put key hash'es in 722.9 gear control module - drain oil from gearbox, remove EHS (elektro-hydraulic system module) , dismount gear control module, try to open it and "renew" and then personalize and make SCN coding with "online", or replace to new one and personalize/SCN it.
    4. put key hash'es in ISM (Inteligent Servo Module) - remove ISM from gearbox, try to open it - write hash'es to CPU (ST10F269) or "renew" to virgin state or mount new ISM and then personalize,make SCN coding (online only), learn servo functions....
    5. get new or used keys and write previously generated dump's.
    Simple five steps Гы_ :-!
    YOU LIKE THIS PLAN ? Can You calculate price for this work ? You get own risk's to damage ISM (~700 Eur), ME/CDI (~1500 Eur), 722.9 - now ordered only with EHS (~1200 Eur) ?
    GO TO DEALER AND ORDER KEY FOR ~200 - 300 Eur !
    Sincerely YOUR'S,
    Ne0
  14. The Following User Says Thank You to Ne0 For This Useful Post:
    Col19 (7th October, 2020)
  15. #29
    gepakg's Avatar
    Feb 2010
    Serbia
    mean EZS,key module based on new NEC mcu after 6/2006,no way to r/w that...
    regards Gepa
    P.M. NeO detailed describe that problem on new w164
    Quote Originally Posted by vwpassat View Post
  16. #30
    Jul 2009
    Neo is right people.
    Its difficult and takes too much time.
    gepakg:
    Yes its till now impossible to hack new NEC MCU in new EIS modules. Even changing mileage is pain in the ass and needs filters.
    But first models W164 have still 9S12.
    Riospeed:
    How do you do it? I opened a few and its Hybrid tech inside. couldnt find any SPI/I2C/Microwire inside. Its all inside MPU. Do you have any Dev pack for this?
    But now i know its possible ,i will continue experimenting...
