Results 1 to 10 of 10
    Feb 2011
    Question Nissan Micra K12 cant program remote on Proxy key (proxy knob)
    Hi I have problem with remote programing proxy key with ID60 transponder on Nissan Micra K12, when I want to add remote doesn't want to program it whith londsor. I have also Nissan in AVDI and I don't know if I can do it with AVDI. Please tell if somebody knows how.
    I try with Lonsdor
    Does anyone know how to resolve the problem and program remote/proxy
    Thanks in advance
    May 2020
    Hello, it is a really nasty car to work on..
    In order to program proxy part of the key, you have to have a valid 4d that starts the car. If that transponder is good and starts the car you can use SBB to code the proxy in the remote menu..
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by profi View Post
    I try with Lonsdor
    Thanks in advance
    Not shore what you own about are you trying to programme remote function or are trying to add key, for add key just copy the chip then programme remote manually.
    Mar 2018
    UK
    Quote Originally Posted by super jumbe View Post
    This is smart key with integrated chip on the board - the remote is programmed in the same time with the chip
    Mar 2018
    Quote Originally Posted by Manta1600 View Post
    hello, the chip is coded separately, the remote control is coded separately, the twist ignition zedfull codes it.
    Mar 2018
    UK
    My fault I messed with the other thread for K13
    https://www.digital-kaos.co.uk/forum...-key-duplicate
    Feb 2011
    Problem solved! I program key whith TDB1000 work perfect
    Feb 2014
    What are the steps to program it? Does the remote work automatically after you add the 4D or you add the transponder first and then the proxy separately through the remote programming menu?
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by autoTkey View Post
    I've did AKL Pathfinder , Qashqai knob. Program first TP then remote.
    You need separate the blade with remote because when tool ask to press remote, it should be nearest the radio.
    Do with X100 Pad2.
  10. The Following User Says Thank You to lion0304 For This Useful Post:
    autoTkey (17th November, 2021)
  11. #10
    Feb 2014
    I found a video on youtu.be made with ADB1000 - there are shown exactly all the steps. Needs the emergency lights to blink all the time too.
    https://www.youtube.com/watch?v=YCXcJIi4NvI
