Clone chip by vvdi Keytool plus
Program remote by MVP Pro or Keymaster DP
The best way
Tapatalk kullanarak iPhone aracılığıyla gönderildi
What is bestway to add key on this 2007 vw crafter?
I have vvdi2/vvdi prog and autel im508/xp400pro
I have done alot of mb keys. I know its a mb eis.
Whats easiest to add key?
I checked inn vvdi prog - immo - vw i only see 9s12xdp512 9s12xdt384. Should i read under benz with 9s12dt256?
And should i just write key by dump. Will this only makr dealer that needs to be learned to car?
Or just exteact pin and cs from dump. And learn with vvdi2?
Thanks😉
The best way
I dont have keytool plus.
Programming of remote is no problem.
Read the EIS like Sprinter on bench with Autel and XP400 or VVDI prog
Make the chip with VVDI2 on XT27 - The chip is ready to start the van no need to write the file back
If you don't have XT27 program ID48 on free position and write the file back
With your tools you can't program remote
MBSERVICENORWAY (25th October, 2021), schouten1977 (25th October, 2021)
Thanks.
If i use xt27 no need to learn either?
Can i learn remote with fvdi 2014 or vcds?
what is xT27
with XT27 just need to read the EIS and program the chip on existing position from the dumb - chip is ready to sart the van no need anything more - This chip will be copy on one of the existing keys
with ID48 you need to read the EIS and program the chip on free position - the tool will generate new file that you must write back to the EIS
I never had success to program the remote with FVDI
I program them with original VCDS under LT3
MBSERVICENORWAY (26th October, 2021), schouten1977 (26th October, 2021)
thanks for info.
will try to adopt remote by vcds and se if it works
XT27 is VVDI Superchip. 2007 Crafter should have EDC16CP34, which is readable with OBD (FVDI). If you only get 6 Bytes CS, you could brute the 7th from working key. But this crafter should have immo3, so all 7 Bytes in ECU. Then you can read ID from working, change ID of XT27 (prepared to Crypto48 before) to same and prepare the key as dealer key. Now it should also start the car without to take out EZS. Remote learning also works with VCDS.
Greets MR...
schouten1977 (27th October, 2021)
With Autel learn remote should also be possible under diagnostic with LT3.
mjoesen (28th October, 2021)
Yes, it‘s safe to read Crafter ecu with fvdi.
Greets MR…
i hat in past also problem to add remote butt with autologic as far i remember it whas no problem butt you have to wait after learning remote 10 min and than it function to add trans ponder i used avdi and hat to connect can hi and low to read ecu whas not complete by obd
i have eis on bench now.
but two of the soldering points on this eis have some resistors where it should connect reset and bkgd . should i just tap in to these resistors ?
UPDATE!
i used vvdi prog and tapped as picture even if resistors where there.
read all ok. program xt27 with vvdi2, then started without problem.
added remote with autel diagnostic.
Manta1600 (5th November, 2021)
can anyone confirm that a crafter will turn ignition with uncut blade ? as long as immo is okey and open elv ?
