I have information for CAS3
unable to update via Abrites
If any of you have encountered this problem
thank you so much
thank you so much
read and post eeprom dump to check
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
BusCan (27th October, 2021)
your eeprom was in boot mode
attached eeprom fixed and original flash , write both and let us know the result
I come to the news on the vehicle I perform a synchronization with DDE CAS all and returned in order
Thank you for your help
topclef (4th November, 2021)
Hello i have the same situation with the a cas 3 from an x5 2012. Is it possible to resend the flash.
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
