Results 1 to 7 of 7
    Dec 2012
    EU
    Default golf 7 2014 tpms coding out from ABS???
    Hi guys..
    can tpms can be switched off in ABS on mk7 golf..
    if so witch bite in coding is for that?
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    Apr 2021
    It's possible.
  3. The Following User Says Thank You to r4nd0mize For This Useful Post:
    gttuning (27th October, 2021)
    fuzz1's Avatar
    Jul 2019
    Hi!
    Can you please share how to do it? Is mk7 Golf MK100?
    Dec 2012
    EU
    Quote Originally Posted by fuzz1 View Post
    Hi!
    Yes MK100
    Sent from my SM-G955F using Tapatalk
  6. The Following User Says Thank You to gttuning For This Useful Post:
    fuzz1 (27th October, 2021)
    Dec 2012
    EU
    Solved..
  8. #6
    fuzz1's Avatar
    Jul 2019
    Anyone willing to share this solution? I think it applies to any mk100 not only vw golf 7. So if anyone been successful on Tiguan or some other vw
  9. #7
    May 2022
    Ukraine
    Привет
    Кто-нибудь готов поделиться этим решением? Я думаю это касается любого mk100 не только vw golf 7. Так что если у кого нибудь получилось на тигуане или каком другом vw
    This easily happens when cars are brought from a certain region, and when the whole world needs to watch 7K9, 7K6 or 7K1 .. I can prove that the programming of the block for katsapstan Rush will be completely different.
    Знаю блоки МК100 для пидораши, могу написать кодировку и включить-отключить все, но для кацапов санкци..))
    The solution is simple, turn off the message in the instrument panel block, the brake block only takes this into account, but if there is a separate block, then it must be turned off from the set in the gateway
