Here you have my file.
Compare files.
Can someone check this files.
Itīs from an Temic SRS 31334738
Inside MC9S12DG128
Present DTC is: SRS-CFFF ...... car did not crashed or deployed any airbags..... not sure about the LOW baterry issue, causing eeprom data failure.
Read with Xprog with the secured option, and had to lift reset and extal
Made myself the CLEAREAD file, but I am not sure if it is fine or NOT.
Best regards
X-Prog 5.60 / Upa-Usb 1.3 / CarProg 4.74 and 7.28 / MiniPro / Galletto 4 VD300 / Digiprog 3 / SVCI 2018 / Autel MP808 / Autocom 2020.23 / USBDM / Skyprog / RT809H / R270+
Compare files.
nezocas (27th October, 2021)
