Results 1 to 12 of 12
    fuzz1's Avatar
    Jul 2019
    Default Among the cheapest tool to work with eeprom and MCU
    If anyone is interested in starting working in eeprom and MCU let me know. I'll share my experience with the cheapest but still workable solution.
    Not claiming it's the best solution but still can do the job.
  2. The Following 2 Users Say Thank You to fuzz1 For This Useful Post:
    blabl (31st October, 2021), stutar (14th November, 2021)
  3. #2
    svenin53's Avatar
    Apr 2020
    Ukraine
    Check CG100, all EEPROM's and many MCU
    Please dear members push the button if my work was helpfull!
    KESS 3, IProg, X-Tool, CG-100, GCPT, etc.
    VAG-Com, KTS-530, Autel MaxiDas, Lexia and many other diagnostic tool's.
  4. The Following 2 Users Say Thank You to svenin53 For This Useful Post:
    fuzz1 (27th October, 2021), stutar (14th November, 2021)
  5. #3
    Feb 2020
    I am interested on it!
  6. #4
    fuzz1's Avatar
    Jul 2019
    Eeprom cheapest ch341a. With some take long tweaks it works. Can read lots of them. Neoprogrammer.
    Mar 2019
    Earth
    xprog does all eeproms and motorola mcu
  8. The Following User Says Thank You to 12manux For This Useful Post:
    brend (25th July, 2022)
  9. #6
    rafal's Avatar
    UK - PL
    vvdi prog now also in good price.................much more stable as xprog
    need help
    now my goal is to buy xp-005
    who will help?
  10. The Following 2 Users Say Thank You to rafal For This Useful Post:
    brend (25th July, 2022), fuzz1 (26th July, 2022)
  11. #7
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by 12manux View Post
    Quote Originally Posted by rafal View Post
    Both genuine tool's is good and both have +/- .
  12. The Following 2 Users Say Thank You to brend For This Useful Post:
    fuzz1 (26th July, 2022), rafal (25th July, 2022)
  13. #8
    fuzz1's Avatar
    Jul 2019
    UPA s is good i must say. Down side hasn't been updated for a while.
    Plus side Rarely corrupts data.
    And probably cheapest doing rh850 chips
  14. #9
    fuzz1's Avatar
    Jul 2019
    To start the work with eeprom
    You need also the following
    A desoldering station
    Heat gun plus soldering iron minimum cost around usd 50
    Third hand with magnifying glass USD 10
    Brass wool to clean tip
    Desoldering wick
    Solder
    Flux
    About usd 100 for everything cheapest i found but does the job
  15. #10
    Aug 2022
    I have ch341, eeproms read write no problem, but i would like to learn more about programming itself, on which address what to change an so on...
  16. #11
    fuzz1's Avatar
    Jul 2019
    I guess if you want to start with programming then a good starting point would be the chip data sheets. They will give you the address
  17. #12
    Oct 2010
    Bucharest
    GQ4-X
    Verry good tool
    BR
