Results 1 to 10 of 10
    rob h's Avatar
    May 2011
    Default Maserati GranTurismo MC9S12DG256 4L91N reading bsi
    Maserati GranTurismo 2008
    501890350000 Marelli bsi
    NBC015.27
    MC9S12DG256CPVE 4L91N qfp112
    Hello guys
    I need to read this bsi, to program keys.
    Hexprog, might have a diagram, under Maserati or Ferrari.
    I should be able to read this, with orange5, or any other prog.
    If anyone would share this, that would be very helpfull.
    Greetings Robbert
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rob h View Post
    NBC015.27
    Hello guys
    Greetings Robbert
    Post your good picture PCB MCU and will make diagram pinout
    rob h's Avatar
    May 2011
    lion0304's Avatar
    Oct 2014
    Wow it too late to me, here is 19H15 and i just come back to home.
    I'll do tomorrow at my office.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    here you go...
  6. The Following 2 Users Say Thank You to figani For This Useful Post:
    capi (10th March, 2022), rob h (27th October, 2021)
    rob h's Avatar
    May 2011
    That does not work,
    i tried with orange5,
    vcc level too low (0mv)
    bkgd error
    vvdiprog read ok.
    I whas worried that it whas secured.
    It was not
    Thank you for your help guys
    Dec 2020
    Is this for cloning purposes or for keys programming?
    If it's for keys you should be able to do it by Obd..
    figani's Avatar
    Feb 2018
    It was not
    unlikely that the pinout is incorrect...
    itīs an older pinout tmpro, wthey would change it if not correct...
    4 lines, always unsecured...
  10. #9
    rob h's Avatar
    May 2011
    Yes, unsecured,
    I found a diagram, of a similar mask.From a ferrari, that whas secured. SO i figured this one could also be.
    And this one appeared not secured.
    I can read it, with vvdiprog, using your connections. So thank you for these Figani,
    However, orange5 failed, using the exact same connections.
    I prepared dealer keys, and used the pin to program all keys, and remotes.
    I bought 2 new remotes, on Ali.
    It would only except 1 remote.
    The second remote, my tool replied it whas allready programmed. Maybe exact same remote id.
    And the remote nr1, the car reacts poorly to it.
    I will try a 147 oem remote soon.
    Anyway, thanks to all off you for helping me.
    Greetings Robbert.
    ps, if i would have had more time, i probable would be able to read it with orange5.
  11. #10
    I also need this connection diagram i can not download this diagram can someone upload it again
