Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
  1. #31
    alclot's Avatar
    Sep 2009
    Melee Island
    Quote Originally Posted by bgcomp80 View Post
    There are two MCU`s XC68HC912D60, one on front side and the other on the rear side .
    You can repair the suspension module by writing the flash and the eeprom in both MCU`s.
    I attached the last software 4Z7 907 553 F .
    The module used was 4Z7 907 553 A and now works with 4Z7 907 553 F software and works perfect .
    Enjoy .
    Hi mate,
    Firts thanks a lot for the dumps.
    I need your help here. I cant program flash by xprog. I tried to erase before but when I writer after give me errors on verifing.
    Can you give a advice how to do it?
    I tried too by vvdi but flash get only 60kb and no 2mb.
    Thanks a lot
  2. The Following User Says Thank You to alclot For This Useful Post:
    Meat-Head (10th July, 2021)
  3. #32
    Mar 2015
    Austria
    I have the same problem...
  4. #33
    Mar 2015
    Austria
    please I have the same problem
  5. #34
    Oct 2021
    I try,
    thanx
  6. #35
    Dec 2021
    Quote Originally Posted by garageozcar View Post
    i know how to repair this unit
    contact me on PM
    Hello
    Your inbox is full can not send you message, maybe you could write me how to do this?
    Thank you
  7. #36
    epicsabi's Avatar
    Sep 2009
    Budapest
    Thank you...
    With your dumps I fixed an Allroad with same fault.
    I changed only the front eeprom.
    My HW: 4Z7907553A
    If I help you don't forget press the THANKS and REPUTATION buttons
  8. The Following User Says Thank You to epicsabi For This Useful Post:
    sdade86 (16th November, 2022)
  9. #37
    Mar 2023
    Hi all,
    Anyone knows if The 4Z7 907 553A is compatible with the 4Z7 907 553 G? My "A" has the 65535 error and i saw a G module applied in a 2001 Allroad. Thanks in advance
  10. #38
    May 2010
    i can repair file easyly
  11. The Following User Says Thank You to garageozcar For This Useful Post:
    DECOCO (28th September, 2023)
  12. #39
    DECOCO's Avatar
    Dec 2009
    north east
    can you help me with front eeprom? dtc
    4Z7 907 553 A 2001 audi a6
    thank you
    work to live
  13. #40
    Mar 2019
    I have a damaged eeprom probably in the controller from audi A6 C5 allroad. Can anyone help me how to connect it to the UPA programmer? where is vcc vss bkgd reset and extal
