Results 1 to 11 of 11
    Sep 2021
    Default Checksum Error while reading [KTAG]
    Hello, i recently tried to read a EDC17C64 With KTAG Clone using Tricore. KTAG Would read no problem until 100% "Reading successfully completed", but while trying to save i get "Checksum error, send the software vendor the backup file".
    My ECU has been tuned before by some tuner, from what i know he simply used some tuning file service, and maybe they have some file protection in place. I've tried to search for NOREAD but without luck. Now i'm wondering if my tool is bad, or its just the fact that the file is somehow protected. Thinking of pulling out my MPPS and trying to read the ecu using the Tricore cable, to see if i get the same result.
    The tuner also won't respond to my emails to send me the original file for my ECU... so i also can't try to flash back the original file.
    I have attached the files. Maybe that someone will be able to recognize if the files are somehow protected, or that the tool is just bad and saved some rubbish or that my KSUITE installation is missing some driver or something.
    Sep 2013
    "The file contains zip-data and requires a pass"
  3. The Following User Says Thank You to pike For This Useful Post:
    kubaK (2nd November, 2021)
    Sep 2021
    Very strange... I have not set any password, but when i put the Micro file in an archive, it somehow appears to have a password?
    Sep 2021
    Here is the full read in 1 file from KTAG
    Jun 2013
    EU
    Use Ksuite 2.22 and forget about that ghost "checksum errors"
  7. The Following User Says Thank You to morgano For This Useful Post:
  8. #6
    Sep 2021
    So its a KSUITE issue? I've used 2.25 when reading this ECU. I do have a 2.23 copy of KSUITE somewhere. I guess i will need to try that. Otherwise i will be on the search for Ksuite 2.22.
  9. #7
    May 2020
    Try to download and install "Visual C ++" and then dump your map file into ecu
  10. The Following User Says Thank You to krzys1540 For This Useful Post:
  11. #8
    Sep 2021
    i will try to install Visual C++ but im 99% sure its already installed. I currently don't want to risk putting these files back on the ECU as i do not have the original file, in case these files are not correctly read from the ECU by KTAG.
  12. #9
    motor25's Avatar
    Dec 2015
    Belarus
    Hi! You should use KSuite223_no_cs, which will not check the Checksum, read the ECU, you read normal flash and eeprom, then write the flash again, by using KSuite223 which supports counting Checksum = and your problem SOLVED)
  13. The Following User Says Thank You to motor25 For This Useful Post:
  14. #10
    Sep 2021
    Thanks, will try this. Hopefully this will solve the issue.
    I will definitely report back on the results.
  15. #11
    Classictinker's Avatar
    Nov 2018
    York, UK
    SOLVED I'm having the same issue...did you resolve this problem?
